Coilmaster DIY Kit problem
Hello,
I received my diy kit a few weeks ago, and have just recently started using it. Everything is good except the ohm reader does not work correctly. Its inconsistent in measuring the resistance. I am also a little disappointed there wasnt any notice of the diy kit v2 as this kit would have suited my needs much better with the larger coilmaster v3. I cannot build a 22g parallel coil on the v1. Anyways whats most important is you correct the issue with my ohm meter. Since you have no contact info on your webpage please contact me asap milhouse4u@hotmail.com
PS: You really should make it easier for users to contact you through the website especially with concerns like these.
