Faulty ohm reader V3 kit
I purchased the V3 kit not long ago. Love this kit, the only issue I had was right out of the box the ohm meter switch was loose. I wasn't too concerned then but maybe I should have been. Now after using the switch sometimes won't turn on. I need to wiggle the switch to get it to light up. And my ohms are reading almost a full .1 off. You wiggle the 510 connector and the ohm reading jumps around. Is there a way to replace just the ohm meter?
Hi Have you contact sale@coil-master.net?
If the issue still didn't solve , please email us.
